Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
Why won't loudspeaker work?
I recently dropped my phone in water, I was able to dry it out and at first the loudspeaker worked but it was very quiet. Then it completely stopped working, so I replaced the loudspeaker. Still didn't work, I thought maybe it was some corrosion on the connections on the charging port, so I cleaned them and still nothing. Now I replaced the charging port and a new speaker and still nothing. What could be causing the loudspeaker to not function?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Hello chsash08 ,
Clean the FPC connectors by isopropyl alcohol and check again.
Punteggio 0
3 Commenti:
I have tried cleaning with isopropyl alcohol and still nothing. I should add no sound comes out of aftermarket speakers and only a faint sound comes out of the original.
da
There is probably still some water damage / corrosion on the logic board under the metal plates. I suggest getting it checked by a professional mobile phone technician that does board level repairs for iPhone.
da
Ok I'll try that thank you
da
Aggiungi la tua risposta
chsash08 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 11
Tutti i Tempi: 132
