Salta al contenuto principale
Il Samsung Galaxy S4 Active è una versione resistente del Galaxy S4. Attualmente, è disponibile solo sulla rete 4G LTE di AT&T.
Getting around screen burn-in
My Galaxy S4 has a burn-in problem. It's good for an hour or so, but then videos become un-watchable, and I have to not use it for a while before it goes back to normal. But every now and then, when I re-boot, the colors appear duller, but much better than when it's all burned-in. This goes away after about ten minutes. Is there a way to force it to stay that way? Some kind of setting or app I can use?
Questa è una buona domanda?
Punteggio 3
1 Commento:
I haven't heard of this issue before, but have you ever considered replacing the LCD? Your phone is older now, and I have the same model. I just recently had to repair mine. You can find a cheap LCD on ebay, but never get one that was refurbished. You may also want to get an S4 for donor parts, which is also available on ebay. Hope this helps!
da
Aggiungi un commento
1 Risposta
I'd replace the lcd, pretty simple process, follow my teardown and you shouldn't have any issues Smontaggio Samsung Galaxy S4 Active
Punteggio 0
Aggiungi la tua risposta
John sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 22
Tutti i Tempi: 1,329
