Salta al contenuto principale
Guide di riparazione, informazioni sullo smontaggio e sulla soluzione problemi per l'iPad Apple di seconda generazione con connettività di rete cellulare 3G GSM (AT&T), disponibile con 16, 32 o 64 GB di archiviazione. È dotato di un processore dual-core A5. Rilasciato a marzo 2011. Identificato dal numero di modello A1396. Le riparazioni richiedono l'uso di calore e una leva attenta.
Backlight does not work ...
My iPad 2 has fallen down.
Since then there is no backlight (the screen seems to work fine because when I use a torch I can see everything on the screen) and also the digitizer cracked.
I have removed the cracked digitizer carefully and checked inside the iPad for further damage which could explain the backlight failure. But I couldn't find any other damage. Everything looks OK.
How can I find what causes the backlight malfunction. Is it the screen or is it something on the board?
Questa è una buona domanda?
Punteggio 2
2 Commenti
Hello again
I cleaned the connectors from the logic board and the LCD screen, but still no backlight. Then I tried to hold the power and home button for 15 seconds and nothing happened. The iPad just turned on. What am I doing wrong with the power and home button combination?
I would also like to ask something else. Is there a schematic or something like that for the backlight circuit so that I could find the right components and test them by using a multimeter? eg voltage, resistance, continuity, etc.
da
If you search up Louis rossmans YouTube channel you may be able to find it there.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
I would say try cleaning the LCD cable connectors from the logic board and the LCD screen itself and at the same time try reseating them and hold the power and home button at the same time for 15 seconds and try turning it on again.
It could either be a faulty screen or the backlight component(s) on the logic board have become broken.
No signs of any physical damage on the LCD screen correct? Well since you can still see display but without backlight I'm leaning more towards logic board component damage like I said before.
Punteggio 3
Aggiungi la tua risposta
Socrates Gertsos sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 6
Ultimi 30 giorni: 16
Tutti i Tempi: 395
