Salta al contenuto principale
Questo dispositivo Android LG è stato rilasciato nell'ottobre del 2015. Il numero di modello del dispositivo utilizzato per creare queste guide è LG-VS990.
Phone will not charge
My phone will not charge. All it does when I plug charger in. Screen stays at 0% (screen shows this) but that's it.. will not charge
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
4 Risposte
Soluzione prescelta
Try replacing the battery like the other comment said. At my phone shop that would be one of the first things we would try. Also try a different charger that might be the issue, the charger you are currently using may not be giving out enough power to charge the battery.
Punteggio 4
First step would be to replace the battery.
Punteggio 1
Did that, replaced the grey battery with an aftermarket one off Ebay. It's been 8 months. Now the phone won't charge again. Did the USB cleaning. Changed chargers. Still it gets hot when charging. Won't charge phone says “slow charge” not sure what to do next
Punteggio 0
I done everything change battery change charger.its says 0 charging charge before using I put on charging 5 hour same problem showing me again
Punteggio 0
Aggiungi la tua risposta
tamrobbins sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 21
Tutti i Tempi: 3,991
