Salta al contenuto principale
Il Samsung Galaxy Note 5 (chiamato Note5) è un telefono di tipo phablet con stilo, prodotto da Samsung e rilasciato nell'agosto 2015.
My note 5 got wet
my note 5 got wet not much but now the back button is not working what should i do to get it back working
Questa è una buona domanda?
Punteggio 5
Aggiungi un commento
4 Risposte
Soluzione prescelta
If its just the back button then you can replace it and all will be right
Sostituzione schermo LCD, scheda USB e pulsante home del Samsung Galaxy Note5
There is a small cuircut board that can be replaced
They can be purchased on amazon or ebay. Sorry there not available here
Punteggio 1
1 Commento:
hi i droped my samsung galaxy note5 in the water and i dont no what to do?
da
My charging port got wet and my phone won't charge correctly, I don't know what to do.
Punteggio 0
1 Commento:
Firstly you can try to make the charging port dry,such as blotting paper,hair drier with very little wind,etc.
If it is still not work,I think you need buy a new charging port flex cable and replace it.
da
Well instead of paying for it to get fixed you can easy just let it completely dry and backup all of your photos,videos,and contacts. And master reset it. That's what I did to mine and I dropped it in a fish tank
Punteggio 0
1 Commento:
I cleaned a clients note 4 thoroughly. Still didn't work as some component chips are burnt.
da
Hi I have a stylo 5 and I just got a stylo 5 and I dropped it in water. After i put it in rice it would only turn on and then say it has no power. My phone won't charge when I plugged it in or show the light that there is a charge. I put it back in the rice to try to dry it out again but I was just wondering what else I could do to try to get it to start charging
Punteggio 0
Aggiungi la tua risposta
vlutchman23 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 11
Tutti i Tempi: 6,588
