Salta al contenuto principale
Il Macintosh Color Classic è stato il Mac all-in-one a colori dei primi anni '90
Sad Mac face error
Sad Mac face when hooking up external hard drive.
Any suggestions???
Questa è una buona domanda?
Punteggio 0
4 Commenti
Will it boot from a floppy? Do you get an error code under the sad Mac face?
da Condividi
It has an internal hard drive.....i haven't got a floppy to try.
It was working fine until i hooked it up to an external
hard drive , that is when i got the mac sad face.
da Condividi
First let's identify your exact machine. Have you disconnected the external drive and tried it? What operating system are you running?
da Condividi
Thanks for your reply.
The Mac Classic was working fine.
Loading up from the internal HD
It has 6.0.7 OS.
Unfortunately I hooked up an external
HD without any knowledge of the spec.
of this HD. Once i started my MacClassic
it gave me the Welcome to Macintosh screen
but then it quickly went to the Mac sad face.
It was difficult to get the code but I believe it
was initially 0000000f/00000003.
I disconnected the external drive and restarted
but it will not load up...somethings i get the sad
face and sometimes give the blank screen with
the mouse pointer.
I tried the reset via the interrupter controller but
still no resolution. I have a system floppy disc
on the way to see if i can boot up with the floppy.
Any suggestions would be greatly appreciated.
Thanks Bob
da Condividi
Aggiungi un commento
1 Risposta
Risposta più utile
Original Mac OS: 6.0.7 Supported Mac OS: 6.0.7-7.5.1, 7.5.3-7.5.5
I assume that you hooked up and external SCSI drive, if the OS was greater than 7.5.5, it would probably produce a Sad Mac face. There were size limitations on hard drives. Has this external ever been successfully used on this machine? We really need as much hardware and software information as you can give, and a bit of time to mull over the problem to remember what the problems of the day were as this machine came out about 1990. I'll try to add to this as I recall issues. If it is giving you an error code that would really help as right now we don't know if it's a hardware or software issue. How recently was the machine running OK? Any know problems with it besides the current one?
UPDATE 6/13/16
xxxx000F Illegal instruction error
00000003
Try restarting the Macintosh with Option and Command keys held down to
rebuild the desktop file (or better yet use TechTool from MicroMat, it's
more thorough). If you still have the problem after doing this it may be
time to do a clean install.
Punteggio 2
1 Commento:
It has 6.0.7 OS.
the mouse pointer.
There was no known problems prior to hooking up
the external drive. This I believe caused the problem.
da Condividi
Aggiungi la tua risposta
Bob sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 5
Ultimi 30 giorni: 15
Tutti i Tempi: 1,875
