Salta al contenuto principale
Un'edizione aggiornata del Samsung Galaxy S II rilasciata nel 2013, identificabile dal numero di modello GT-I9105/P.
How can I fix my screen?
I droped my phone, actually it's not the first time but it was a hard one, and when i check it there was a black spot on the screen, i knew then that it's broken.
But after a few minutes the spot covered all the screen; though i still can hear the lock screen or when i turn it on so it's still working.
i think i need to change the screen or something like that but i don't know how ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Yes you can replace the screen but the cost of replacement would probably be more than the phone is worth I see on ebay the going rate is 125 for a replacement and you will need a complete replacement LCD digitizer and glass complete .
http://www.ebay.ca/sch/i.html?_odkw=Sams...
this is a tear down video for your phone
https://www.youtube.com/watch?v=pDkvz9fU...
Everything can be fixed but not everything should be . If you have important data on the phone even with a broken screen you should be able to connect and retrieve the info unless your phone is password locked
Hope this helps
Punteggio 3
1 Commento:
thank you so much I really appreciate it.
da
Aggiungi la tua risposta
simo5991 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 3
Tutti i Tempi: 330
