Salta al contenuto principale
Fotocamera digitale compatta punta e scatta da 7,1 Megapixel uscita nel settembre 2006.
On/off switch does not work
The on/off switch has been hard to turn on or off for a long time, now it does not work at all
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I also had this problem. I believe it will not turn on because the lens is stuck and cannot extend. This appears to be a minor but persistent problem which is solved by gently hitting the camera on the edge of your desk, a table or other. I said gently, then the lens extends and the camera works until the next time the lens decides to stick. Remember, I said gently.
Punteggio 0
Aggiungi la tua risposta
pauldgoss sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 12
Tutti i Tempi: 425
