Salta al contenuto principale
Guide e informazioni di riparazione per la seconda generazione della Honda Odyssey nordamericana, prodotta tra il 1999 e il 2004.
2004 honda odessey problem.
my 2004 honda odyssey cuts out while driving
all of the dash lights come on and the engine shuts off
start the car up again and runs fine for awhile. A few days later it does it again.
Also the green key light will stay on after each occurance
A very intermittent problem.
Thanks.
Questa è una buona domanda?
Punteggio 2
2 Commenti
My radio need code it not working
da
Did you find out what was causing the issue?
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
I have seen this before and it has to do with the chip the car needs to read in the key . There is an rdf reader in the steering column that is shorting out and setting off the security to kill the car. it blanks out when hitting a bump and the chip in the key looses its signal and all of a sudden the security kicks in and kills the car. Something to check . Do you have more than one key for the van ? If so try a different key and see if it makes a difference. Hope this helps
Punteggio 4
Aggiungi la tua risposta
Taller sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 17
Tutti i Tempi: 2,247
