Salta al contenuto principale
Informazioni e guide di riparazione per i modelli MacBook Pro con display da 13".
9745 Domande Visualizza tutte
Domanda Chiusa
Hard drive not recognized.
Macbook pro doesn't see hard drive. Removed hard drive ran S.M.A.R.T & sector test everything was ok. Connected hard drive to usb and it booted up. Would the problem be the hard drive cable or the motherboard?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
I really don't have enough information on the history of this drive to give you a good answer. It sounds to me that it may be formatted incorrectly. Could be Apple Partition map instead of GUID. Where did it come from, what machine was it formatted on, why are you replacing it, did you boot up from it using an external enclosure
Punteggio 1
1 Commento:
Yes
the cable, the connectors the buss itself could be where the fault lies.
Examining the connectors under a high power magnifying glass, and if possible swapping ribbon cables to see if the problem follows are about all the DIY test you can do.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 998
