Salta al contenuto principale
Il Nokia Lumia 900 è uno smartphone basato su Windows Phone 7.5 con supporto 4G LTE e touchscreen capacitivo AMOLED ClearBlack.
Can I change this flex?
Hi there, look, i've bought a nokia lumia 900 screen (all), but when i was trying to change it with the broken one, i accidentally broke the digitizer flex, so the screen works, but not the search, windows and back buttons.. is there any possibility to change only that thing (that entire flex, or module) with the screen that is broken? in the broken screen those 3 buttons are working fine..
Thanks!
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta più utile
Sure, but it would cost a fortune to repair a flex cable as a very expensive machine would be required to do this.
You're better off buying a new LCD + Digitizer. But if the glass can be easily replaceable withot damaging the LCD when separating the glass the. You can replace just the Digitizer.
Punteggio 2
1 Commento:
thanks! but now i've found that in some sites, they sell the navigation flex. I mean, if they sell it, it can change it, only that thing.. but, i dont know how to remove that, because in the broken one, all that "navigation flex cable" is perfect, and in the new one is broken.. sorry for my english, if you want i can send you some pictures..
da
Aggiungi la tua risposta
Agustin Recoba sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 15
Tutti i Tempi: 302
