Salta al contenuto principale
Apple ha rilasciato l'iPad Air, più sottile e potenziato, il 1° novembre 2013, disponibile nelle colorazioni Grigio siderale o Argento. Include il processore personalizzato A7 ed è disponibile nelle configurazioni da 16, 32, 64 e 128 GB.
How to bypass the iPad passcode
Hello everyone! My grandmother just got an iPad recently and managed to put a passcode on it and not remember what the passcode is. I have tried putting the iPad into recovery mode and restoring it. However, there is an error every time I try to do this. In addition, I have tried using icloud. To erase the iPad, you need wifi and she has disabled it by trying her passcode to the point where it says "connect to itunes" like it is permanently disabled. PLEASE HELP!!!!
Questa è una buona domanda?
Punteggio 5
1 Commento
do i need to have an internet connection while doing this action and connect to the PC?
da
Aggiungi un commento
6 Risposte
Risposta più utile
While you try to restore the I-pad, Take it to DFU mode and try to restore it.
DFU Mode: Press the Power button and Home Button at the same time till screen goes off,
After 5 secs of doing that, leave the power button and just press the home button till
it goes to DFU mode. After that, try to restore the I-Pad
Hope it Works.
Punteggio 2
Follow what Patrick said, make sure the iPad is DFU mode otherwise it will not work. Make sure you are using an original apple charging cord, if it doesn't work the first time try another charging cord or computer, sometime your settings on the computer will prevent the new software from going into the iPad properly.
Punteggio 1
If you wish on a star you can do anything in one click.
Punteggio 1
There is a "what" error when you try to restore?
Be specific enough please.
Punteggio 0
A program named 4uKey works for that issue.
bypass ipad passcode in 1 click.
Punteggio 0
1 Commento:
Can the program bring peace to the world in one click too ?
da
In such a situation, you can try an iPad passcode unlocker to help you. There are many such tools online. I have ever used one called Joyoshare iPasscode Unlocker to factory reset my locked iPad. It is easy to use. Of course, you can google this kind of unlocking tool and choose one that you desire.
Punteggio 0
Aggiungi la tua risposta
morganmachado1 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 6
Ultimi 30 giorni: 36
Tutti i Tempi: 5,903
