Salta al contenuto principale
Informazioni di riparazione per la seconda iterazione dell'Aspire S7, il modello S7-392. Si tratta di un ultrabook di fascia alta da 13" prodotto da Acer.
No Bootable Device Error after keyboard replacement
I have an Acer Aspire S7 and replaced a faulty keyboard. However I did not disconnect the battery during the replacement and may have corrupted something in the process. After the replacement, when I boot up the computer I get a "no available boot device" error and there are no drives found in the BIOS, indicating that it can't access the hard drive. Since these SSD's seem to be hot-swappable, I don't think I "wiped" the drive during dissembley, but I'm not sure.
Also, the battery doesn't function and doesn't register as charging.
Everything seems plugged in properly so I'm a little at a loss
My initial question what could I have potentially corrupted during the repair? How can I systematically determine what that thing is?
Thanks!
p.s. keyboard works great :P
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
My Acer S7 ultrabook some problem switch on (No bootablet please reset system) but will hold the button switch on back not have working
Punteggio 0
Aggiungi la tua risposta
ajkrell sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 22
Tutti i Tempi: 678
