Salta al contenuto principale
Not Firing Or Turing On.
I have one of the Zeus Rival guns and for some reason its not firing at all. I have the ridiculous 6 C batteries in right but still nothing. I have also made sure to turn off the safety. I am going to have to open her up soon if I am unable to find a resolution. If anybody has any ideas feel free to help.
Questa è una buona domanda?
Punteggio 12
12 Commenti
I had this problem too but it turns out there is a piece that connects to the top of the magazine which pushes a button which enables you to pull the second trigger and power it on.(my dad and I had to take apart the whole gun to figure it out lol
da
Mine shoots but jams every time
da
When you open the hatch on the right of the gun, you have to push it down very hard to lock in place, then it works
da
Lewis Conner, thanks, that did it.
da
I have a problem with my rival Zeus I have not checked the batteries yet but it does not want to let me pull the trigger does anyone have a fix ?
da
Mostra 7 altri commenti
Aggiungi un commento
12 Risposte
Risposta più utile
Try re-solderingvthe wire in the battery tray
Punteggio 3
6 Commenti:
If the trap door near the barrel is open even slightly it will not fire.
da
THANK you. I was about to return the %#*@ thing lol
da
Yes... the trap door being completely closed was the key! Thank you!!!
da
Holy $@$* I was about to return it thank u so much it was the trap door shut it ALLLL the way even when u think it’s closed
da
OMG I just bought all new batteries and was about to return it. Wow thank you!
da
Mostra 1 altri commenti
First you look at the orange hatch , the one that opens up. Second that hatch is not fully closed so you need to close it until you here a snap or a click then it should work.
Punteggio 3
2 Commenti:
It is awesome
da
Incredible simple, this was the problem, thanks.
da
Did ya unjam the wheel part? I'd there is a ball in the wheel part it will not fire.
Punteggio 2
2 Commenti:
I keep on taking it out but it rejams and bearly goes far
da
Mine does the same but mine doesn't even shoot
da
On some nerf rival there is a trap to un jammed when the ball is stuck and if this trap is not correctly closed(you should heatd a “clic”) the electric motor doesn’t work. I spent 1 hour disassembling the gun etc… when i realised i was ready to send it back.
hope it’s helpfull.
Punteggio 2
Did u figure this out?
Punteggio 1
Ive done all of this and it still doesn’t work.
Punteggio 1
what do you do when the moderriser on the gun dose not work
Punteggio 1
This is a common issue. The springs touching the battery pack get compressed and need to be stretched out. It’s a simple operation, remove the battery pack and unscrew each screw. Pop the left side off then pull, baby, pull. On the springs that is.
Punteggio 0
How to fix nerf gun rifle
Punteggio 0
1 Commento:
how do you fix one
da
e
w3=-ero40ynihio-jk-4p5ymnt-35g
Punteggio 0
When closing the jam clearing hatch/port near the muzzle on the right side, you need to pull the sliding door forcefully until it clicks (there is no indication of this, and the door appears closed, but you have to pull hard until it clicks). That would engage a switch to deactivate a safety feature and connect the power to the pump.
Punteggio 0
My is not reloading
Punteggio 0
Aggiungi la tua risposta
Joseph sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 62
Tutti i Tempi: 46,300
