Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
1233 Domande Visualizza tutte
Domanda Chiusa
LCD screen unresponsive when on flat surface. Works fine when in hand
I have a very strange issue. The LCD screen was changed on an iPhone 5C. The screen touch works fine when it is held in your hand and is fully responsive. As soon as you put it down on a flat surface the screen touch doesn't work any more. As soon as you pick it up again it works again. I have uploaded a video so you can see what is going on. It has been tested in another 5C and it has the same issue. Also have a 5S with the same issue.
iPhone 5C LCD Screen Only Works When Held In Hand
Any suggestions
Questa è una buona domanda?
Punteggio 0
1 Commento:
Did you try with different screen?
da
Aggiungi un commento
2 Risposte
Yes tried with a different screen
Punteggio 0
1 Commento:
So I don't know what is going on with your phone then. Sorry. Hope someone can help you
da
Might be a problem with your Digitizer/LCD. You have the option to replace the digittizer itself and try or you can also replace both the LCD and the digitzer and see if that helps your phone.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 930
