Salta al contenuto principale
L'asciugatrice elettrica Kenmore Elite HE3 ha una capacità di 7,2 piedi cubi (circa 204 litri) ed è prodotta da Kenmore.
Timer won't shut dryer off
My dryer will dry clothes fine and heats up correctly after setting it up on a cycle. However, the drum keeps turning after the cycle is complete. It shuts off when I open the door but comes back on when I close it. I have to keep door open to not waste energy. What can I do to fix this issue?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Hi,
There was an answer for this problem on iFixit back in 2016 by @mayer.
It’s for an earlier model but could be the same reasons.
Why won't my dryer turn off
It gives possible causes of the problem you described.
Hope this helps
Punteggio 0
2 Commenti:
The original answer posted covered lots of options but not the cure for mine. I have posted a comment on that thread with the solution that works for me (replacing the timer unit).
da
I searched @mayer's page for dryer and drum; not found. So even though Helpful Harry says that there was an answer, I haven't seen it. Meanwhile I've found some possible solutions from other sites, and they are leading me to a control board replacement. For example... https://www.youtube.com/watch?v=V0_Ty4Cc...
Thank you.
da
Aggiungi la tua risposta
Oscar Gutierrez sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 15
Tutti i Tempi: 338
