Salta al contenuto principale
Parte della serie G di Lenovo, una linea di computer portatili per uso quotidiano lanciata nel novembre 2012.
My machine won't regulate processor thermal heat
Hi i'm Leslie,
Ive got a lenovo g580, i3 with 8GB RAM running on Windows 10 (v1511) ,
my main problem is the Processor Thermal.
I tested my machine with the Intel Processor Diagnostic Tool 64bit latest version, managed to pass everything else but failed with the following error :
Entering run forever
1 degrees C below maximum
Test Result - FAIL
Expected Greater than 1 degrees below max
Received 1 degrees below max
Test FAILED
Please check your Processor Thermal Solution
Kindly help us with a solution for the problem because its been making my machine shut down unsuspectedly without notifying. This has caused instability when i'm working throughout the day.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi,
Is the CPU fan running? Are the vents clear and unobstructed? Use Task Manager to see what % the CPU is running at. If high % and you are not doing much on the laptop, check what applications or processes are using the CPU the most and why
Punteggio 2
Aggiungi la tua risposta
Leslie sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 8
Tutti i Tempi: 517
