Salta al contenuto principale
Rilasciato nell'aprile 2015, conosciuto anche con il nome di modello A10-70F ('F' indica che si tratta di un modello solo Wi-Fi).
Camera quality is blurry
The rear-facing camera always produces pictures that are blurry even after I clean the camera lens.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione prescelta
If the camera is still taking low quality pictures after you have cleaned the camera lens, you should think about replacing your tablet camera. The link to the repair guide for the Lenovo Tab 2 A10-70 will be available soon.
Link to Troubleshooting: Lenovo TAB 2 A10-70 Troubleshooting
Punteggio 5
Hello, I've had this problem before as well. How I fixed it was easy. First, you want to make sure that the object is in focus if not focused make sure to hold the screen till the camera focuses. That should help solve the outcome of blurry pictures.
Link to Troubleshooting Page: Lenovo TAB 2 A10-70 Troubleshooting
Punteggio 1
1 Commento:
Undernieth the caseing the foil was still intact to the camera, took it of, done.
da
Aggiungi la tua risposta
Stacy Tinner sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 13
Tutti i Tempi: 10,725
