For those who have intermittent camera after a fall/drop: TAKE case off and any accessory such as S pen. Get hair dryer, concentrate on the back top because that's where you will gently pry open with a thin pvc nfc ( or similar) card, guitar pick, or other pry tool. You need to continue applying heat, until your pried enough of the cover up to see and press the camera ribbon cable end down to make sure it's not lose. It doesn't have to be snug to sometimes work. I've done thru that with a Samsung.
Currently, I've a Galaxy Note 9 that's *supposedly* rated highly water resistant and can withstand up to 1-2 minute with NO damage, and to 5min even. Yeah, right!
Mine had a completely sealed Otter Box on and fell into a washing machine that wasn't even full enough for the water to touch the top clothes, which is where it fell. I grabbed it immediately. It whacked out, screen fritzed with colored rainbow lines. Did not even seen more than damp. Want not submerged, is the thing. Now, 2 weeks later, opening the camera does 1 of 3 things: Opens with a black screen then state camera is busy then “bout 4 responding, close app" 2. Opens to black screen and freezes entire phone and causes flashlight to come on and stay on even when it shuts down itself, staying on all night 3. Just stays black.
Tried third party apps, selfie only app worked a few times when Icould force front to work. Now, Im taking this $1k thing apart since Asurion via Verizon does not help in my area and will follow the above directions that I'd already figured out halfway for myself. If possible, I'll update what I find under the hood and try linking to or inserting photos. I think it may be disconnected and wet from the fall.
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
16 Commenti
I dropped my phone in my tub of water and the screen immediately filled with water. I fixed that problem for a few nights by letting it air dry but there are still some watermarks in the top left corner that I don't really mind. My problem is that, my camera and any other apps that are provided with camera scripts have all gone black screened and pop up such things as "Warning Camera failed!". I have a Samsung (Galaxy J3 prime.) If anyone has any ideas on how I can fix this, please reply or shoot me an email at tbbrowsbaby1000@gmail.com and I'll make sure to reply with a big thanks!
da ItsMeTB
Can you please send it to me too
I have the same problem
da MISCHIEF MANAGED
Basically I dropped my phone in the bath and it was hot water. Everything works fine except the front camera the top of it is white and when I use it it makes pictures blurry. Can I fix this myself?
da millieannewaghorn
I honestly do not know....I came on here for an answer.
da Albert Einstein
Mine works on and off after my first cat dropped it in the tub, then after my camera started working a bit my new cat spilled water on it. Rice worked but now my camera works on and off, I can't use it sometimes and I have to wait overnight to use it. I did everything google said. If you have a solution and went through this somewhat please tell me.
da Brooklyn Elsea
Mostra altri 11 commenti
