Salta al contenuto principale
L'Inspiron 15-3521 è dotato di una funzione opzionale touch screen e di un display da 15,6". Questo portatile presenta inoltre una finitura opaca e una tastiera completa di tastierino numerico.
No Boot Device Found
Just replaced my hard drive with a new one from ifixit, when running diagnostics it now shows no errors when previously it said there was a problem with the hard drive. On boot up it states: No Boot Device Found. Press any key to reboot machine
On the boot menu after pressing F2, I only have the following options:
LEGACY BOOT: (which is gray)
UEFI BOOT:
When selecting UEFI BOOT:
UEFI Onboard LAN IPv4
UEFI Onboard LAN IPv6
It doesn't seem to matter which order they are in
After reading all other forums, I have not found a solution to this.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione prescelta
did you format your drive re-install your Operating system on the new hard drive? When you boot to BIOS check if the hard drive is getting detected there or not. Here are the steps:
Restart the system and immediately start tapping the 'F2' key to enter the 'BIOS'.
Please check what is written next to 'Fixed HDD'.
Double check your installation and your drives compatibility
Punteggio 2
So if I enter f2 and enter bio what next, because my dell is still on fixed HDD ( not detected) . What should I do next?
Punteggio 0
1 Commento:
tucrkilerita what is your computers make and model? This is a new hard drive?
da
Aggiungi la tua risposta
Karen Chandler sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 15
Tutti i Tempi: 15,383
