Salta al contenuto principale
The ProScan PLT7223G Tablet, manufactured by Curtis International, is a basic Wi-Fi enabled tablet that is intended for personal or professional use.
Why won't my tablet charge?
-I have tried plugging in my charger with the tablet to several outlets in my home but it still won't charge.
-I have tried replacing my charging cable and wall adapter but that doesn't seem to be the issue.
-I have attempted the factory reset but that didn't help.
I was wondering if it could be an issue with the charging port or the battery itself. Any Ideas?
Questa è una buona domanda?
Punteggio 4
1 Commento
My tablet with not hold a charge. Charger gets warm after few minutes
da
Aggiungi un commento
3 Risposte
Soluzione prescelta
The problems may caused by a broken charger, dirty charging port or faulty charging port. To fix the problem, check the troubleshooting page for not charge part.Proscan Will Not Charge
Punteggio 4
Risposta più utile
Hard to say exactly what it is, without looking at it, but my iPhone had the same issue and it was differently the charging port. I had to have it at a specific angle to catch the charge. It would seem to be an issue with the port, where a battery would slowly hold less and less of a charge before not holding any charge.
Punteggio 4
Your iPhone had to be used in a Angeles
Punteggio 0
Aggiungi la tua risposta
Daniel Hernandez sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 19
Tutti i Tempi: 4,657
