Salta al contenuto principale
Display da 15,6 pollici. Identificato dal codice modello: NP470R5E-K02UB. Questo dispositivo è stato rilasciato nell'agosto del 2013.
Do not attempt keyboard replacement.
Hey everyone,
This isn't so much a question as a word of advise. Do NOT attempt to replace the keyboard on this device without purchasing a new palmrest/top case as well. The keyboard is held in by what looks like plastic rivets, and is VERY difficult to replace on your own. I've attempted a keyboard-only repair a few times, and I won't let it happen again. It takes much too long to tear off all the plastic rivets and glue the new keyboard down, and you end up with a less than satisfactory repair every time.
Questa è una buona domanda?
Punteggio 4
1 Commento
Where did you order the palmrest/top case that you recommended. If you could provide the part number, that might be helpful if a future repair is required by someone who reviews the post.
da
Aggiungi un commento
1 Risposta
Risposta più utile
I had the same experience. Had to completely disassemble the laptop to get to the keyboard, then cut off the plastic rivets with a box cutter to remove it. Well, OK, my student worker did. I supervised. It's nice to have minions. It did turn out well but took a few hours.
Punteggio 1
1 Commento:
hi brianstrech,
how did you guys glue the keyboard back?
da
Aggiungi la tua risposta
Max Rysdon sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 12
Tutti i Tempi: 1,943
