Salta al contenuto principale
The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
136 Domande Visualizza tutte
Is the charging port replaceable for my GALAXY TAB 4 7.0
I am hoping for some direction on repairing the charge port on a Samsung Galaxy Tab 4 7.0 MODEL #SM-T237P. Is this part soldered? Also is the charge port the same for all of the tab 4 7.0 model's???
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Hi,
The part that you want (it is the soldered on type) is available on Ebay http://www.ebay.com/sch/i.html?_from=R40... I do not know if they are the same for all Galaxy 4 7.0 models
Here is a link which shows how to replace the battery in your Tab. It is handy as it shows how to open your Tab. At 1:46 minutes into the video you can see the charging port (which is soldered on) on the right hand side of the Tab, as seen).
https://www.youtube.com/watch?v=byR1_wgN...
Here is a link which shows how to remove /replace the charging port on a similar model Tab (not the same model but hopefully good enough to give you an idea on how to do it).
https://www.youtube.com/watch?v=4mcXJVbK...
Hopefully this will be of some help.
Punteggio 3
Can I fix the port on my galaxy tablet four by myself all
Punteggio 0
1 Commento:
Hi,
It is not a job for novices. You will need SMD soldering expertise and tools to perform the repair. You can cause more damage if you don't know what to do.
It may be better if you take it to a reputable, professional mobile phone or laptop repair service and ask for a quote.
da
You can get the charging port here. Also here is a YouTube video about how to repalce a charging port.
Punteggio 0
Aggiungi la tua risposta
amber hyatt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 7
Tutti i Tempi: 15,220
