How can I reset bios password?
I forgot my Bois password and now i can't into the setup
Questa è una buona domanda?
Luckily it is an older laptop. There are different ways of doing it.
To reset the bios in an Acer 5100 you need to remove your DDR2 memory sticks, below you can see "j2", it is a 3 pin jumper close to the battery look which 2 of the 3 pin it is on, then move the little plastic tab from those two to the other two pins and then hit the power button once. When you have done this, return the tab back to the original setting. This should reset the bios. Should that not work, you can take more drastic steps and follow the thread here by a user name Robinhood69. It is very involved but should work as well. the other way is to obtain software BIOS/CMOS password recovery tools and yes Zain's flashing of the BIOS would also do it....Good Luck and let us know how it is going.
flash (update) the bios from a bootable CD. You'll find disc images for this on the manufacturer's website.
Otwerwise, use a BIOS/CMOS Password Recovery Tool (link: http://www.biospasswordrecovery.com/ ).
It works with Acer BIOS and a lot of others. Good luck...
Source:
OKAY i am serious now
Use these backdoor passwords it will work
A.M.I.
AAAMMMII
AMI
AMI?SW
AMI_SW
BIOS
CONDO
HEWITT RAND
LKWPETER
MI
Oder
PASSWORD
Award BIOS Backdoor Passwords:
(eight spaces)
01322222
589589
589721
595595
598598
ALFAROME
ALLY
ALLy
aLLY
aLLy
aPAf
award
AWARD PW
AWARD SW
AWARD?SW
AWARD_PW
AWARD_SW
AWKWARD
awkward
IOSTAR
CONCAT
CONDO
Condo
condo
d8on
djonet
HLT
J256
J262
j262
j322
j332
J64
KDD
LKWPETER
Lkwpeter
PINT
pint
SER
SKY_FOXSYXZ
SKY_FOX
syxz
SYXZ
TTPTHA
ZAAAADA
ZAAADA
ZBAAACA
ZJAAADC
Russian Award BIOS Passwords:
%øåñòü ïpîáåëîâ%
%äåâÿòü ïpîáåëîâ%
Phoenix Backdoor BIOS Passwords:
BIOS
CMOS
phoenix
PHOENIX
Other Manufcaturers Backdoor Passwords: (manufacturer name – password)
VOBIS and IBM – merlin
Dell – Dell
Biostar – Biostar
Compaq – Compaq
Enox – xo11nE
Epox – central
Freetech – Posterie
IWill – iwill
Jetway – spooml
Packard Bell – bell9
QDI – QDI
Siemens – SKY_FOX
SOYO – SY_MB
TMC – BIGO
Toshiba – Toshiba
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 26
Tutti i Tempi: 26,527
2 Commenti
When you turn on the computer on and after it boots up or when it's booting up press the f1 key and it should take you to CMOS where you can change your password. I've done this on previous computers and it has worked.
da paula
BIOS hdd password
password/unlock key
da VIMAL
