Salta al contenuto principale
Informazioni su riparazione e smontaggio delle cuffie wireless Logitech H800. Supportano 2,4 GHz e Bluetooth. Rilasciate nel 2011. Numero di modello: 981-000337.
Micro-USB jack is broken
Ive recently broken the charging micro-usb jack on my h800 headset. At first i could charge if i put it in the right position making it impossible to use and charge the headset at the same time. Now it doesnt want to charge at all and i need to know if it is possible to get the jack replaced or just go buy a new headset.
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
2 Risposte
Risposta più utile
It's can be opened, but replacing the USB is not easy unless you have the correct tools.
Punteggio 1
You have to use hot air gun and iron.
Look near you for some repairing center or just somewhere where smartphones are repaired.
It will cost something about 20$ I think.
Punteggio 1
Aggiungi la tua risposta
Matache David sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 20
Tutti i Tempi: 2,204
