Salta al contenuto principale
Il Microsoft Surface Pro 2 è un ibrido tablet/portatile rilasciato nel 2013. Il Surface Pro 2 è il successore del Surface Pro di Microsoft e utilizza Windows 8.1 fino a Windows 10.
Surface Pro 2 shutdown randomly
My surface Pro 2 shutdowns randomly without reasons, I've found a pattern: every 30 minutes with 0 seconds! exactly 30 minutes. Tried resetting, installing recovery image. I've had an issue installing recovery image: when I choose "fully clean the drive" after 30 minutes 0 seconds (33% installing) surface shutdowns by itself. I can only install the recovery image choosing the "just remove my files" option because takes less than 30 minutes. It's not a driver issue, not an OS issue, not heat issue, as crazy as it sound, it's a time issue (¿planned obsolescence?)
I CAN'T FULLY CLEAN THE DRIVE the Surface turns off by itself before finnish. I've contacted 4 times to Microsoft support and last time they were unable to get me another solution.
Questa è una buona domanda?
Punteggio 0
2 Commenti:
you should try bios reset first and and seee
da
I've tried to reset from bios menu but there's no way to do it
da
Aggiungi un commento
2 Risposte
if your are really sure about the timing then i suggest you crack it open and disassemble the battery connector and do it with direct charger plugged in... and observe again
Punteggio 0
2 Commenti:
I've tried any mehod, I dissasembled and disconected the battery, tried to reset bios with this, reinstalled factory recovery without connecting battery, tested all without battery and shutdowns are stilll here. I don't want to assemble before try... i don't know what to try
da
try subjecting your device to a cooling device e.i.. direct a fan to the device as u power it on and observe the shutdown timing....
da
Same issue here Anyone ?
These POS's need to be dumped on the corporate door step like the dung they are attempting to say is marketable.
Punteggio 0
Aggiungi la tua risposta
brunonemer sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 8
Ultimi 30 giorni: 14
Tutti i Tempi: 1,612
