Salta al contenuto principale
Location of Processor Topside Temperature Sensor
My 12" PowerBook is suffering from the notorious Narcolepsy problems, which have been well documented for this range.
The consensus solution seems to be to remove a faulty temperature sensor which sleeps the machine by giving erratic 'overtemp' outputs.
On the 15" and 17" models there are visual guides available online to locate the Trackpad sensor, which seems to be at fault on those models.
However the sensor giving the funny readings on my 12" (and others people's, it seems) is the Processor Topside Sensor. Both Temperature Monitor and ThermographX agree on this.
I'm well out of warranty and fancy throwing caution to the wind and clipping this off. Could anyone tell me where in the machine it is?
Thanks in advance.
Questa è una buona domanda?
Punteggio 2
1 Commento
I noticed you never got an answer to this. Are you still having this problem?
da
Aggiungi un commento
3 Risposte
Risposta più utile
Teymur, there are lots of users out there looking for that sensor right now. In the meantime check this site out. It somewhat explains how to disable the sensor from the firmware/software side. Instead of physical disabling or replacing it, just shut it down http://www.swisswuff.ch/joomla/index.php... Of course I suppose it might shut down sensor that are needed to function right. So do proceed with that in mind.Hope this helps until we find the location of the sensor...good luck
Punteggio 1
1 Commento:
check on here to somewhat different approach but nothing to lose http://web.mac.com/rickcameron/iWeb/Elec... here is the service source and not sure if that will help out http://www.macbook-fr.com/IMG/pdf/PowerB... ...I am on a mission now :)
da
machead3:
Sadly no solution yet. I did open the machine up using the iFixit guide and have a look around, but the internal layout is pretty different to the 15" and 17" models which, as I noted above, have illustrated guides available to track down the faulty sensor. In any case, the problem on those is the trackpad sensor, which I found doesn't exist on the 12".
Unfortunately the machine is not really functional. It's only useable for five minutes before it starts repeatedly falling asleep. So its data has been moved elsewhere and all it's doing at the moment is sitting on my shelf.
I took it into a Genius Bar here in London; as I suspected they suggested replacing the whole logic board. This is obviously not economically sensible. Seems such a pity that this tiny component is making an otherwise-functional computer useless.
I thought this topic would have been forgotten about long ago - thanks for digging it up! Have you any ideas?
Punteggio 0
OldTurkey
Happy new year and thanks for your reply.
I had found the first site when I first tried to solve this problem. The author indicates that his solution didn't work permanently (only for "several weeks"). This is why I was trying to find a way to do the hardware mod of hacking out the temperature sensor - a method which seems to be universally successful when applied to 15" and 17" models. Despite all that - and I'm really no whizz with the Terminal - there's really nothing to lose so I may give it a go anyway.
The second link gives me a 404 error.
If your mission digs anything further up, I'd be very grateful to hear it.
Punteggio 0
1 Commento:
Teymur so far no luck about the location for the sensor but I got an interesting reply regarding the narcolepsy i put it in quotes and thought it might be worthwhile to check it out "Actually, it is more common for the reed switch to be broken and cause the
machine to have narcolepsy. On top of the superdrive on some 12" Aluminum
models there is a little glass tube that has a wire running along the superdrive
and into the DC-DC board (battery board). Examine the glass on it to see if it
is broken, even in the slightest cracking. If it is, then that will be what is
causing the sleep issues."
da
Aggiungi la tua risposta
Teymur sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 15
Tutti i Tempi: 3,380
