Salta al contenuto principale
Il Macintosh Powerbook 140 è stato uno dei primi computer portatili Apple. È dotato di un cavo di alimentazione di grandi dimensioni, una batteria, una trackball invece di un trackpad, ed è stato uno dei primi computer Apple a utilizzare un floppy disk interno e un'altezza della tastiera regolabile. È stato inoltre il primo computer portatile a presentare una tastiera posizionata verso la parte posteriore dell'unità computer.
How do I fix my screen?
Hello. If anyone knows about older Apple computers, I need your help. I recently got an old Macintosh Powerbook 140. I have plugged it in, and when I power it on, I hear the startup sound, and the speakers emit a tone, but the screen displays nothing. I have checked for any visible damage, and there appears to be none. It may be of note that the computer hasn't been used at all for the past 20 years. I do know that the last report of its use was that the screen was a bit touchy. 20 years ago, the screen could only be seen from the correct angle, but now there is nothing. Can anyone help?
I should also note that I have little experience with physical electronics. I work well with technical stuff, but I only have a basic understanding of electronic terms. If you could explain and terms for me, that would be great.
Questa è una buona domanda?
Punteggio 1
1 Commento
Update: I have been getting tiny lines of light on the display for just a few seconds. not sure if it means anything but I thought it might be good to know.
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
Sounds like a bad inverter. Move the screen back an forth and seem if you can discern anything on the screen.
Punteggio 2
3 Commenti:
I can't see anything on the screen when I tilt it or look from a different angle. i do however know that when it was last used, this solution worked, but it doesn't now.
da
Proceed as Apple suggest:" No display, but computer appears to operate correctly.
1 Adjust screen contrast.
2 Check display cable, inverter board, interconnect board, daughterboard, and motherboard connections.
3 Replace inverter board.
4 Replace interconnect board.
5 Add shim to display cable. Refer to Additional Procedures.
6 Replace power cable.
7 Replace display cable.
8 Replace FSTN display (all repairers) or replace activematrix
display (CPRC/ international repairers only).
9 Replace daughterboard.
10 Replace motherboard.
da
Ok. Could you explain some of the terms for me? I'm not great with the technical terminology. Also, I only have one external cable. It's the power cable. Should I have more?
da
hello
very common failure in these machines : LCD caps and inverter caps are gone , must recap lcd screen and inverter with new capacitors , i solved this problem with all my powerbooks 140-145b-160
see this video :https://www.youtube.com/watch?v=XP-fWaDb...
Punteggio 2
Aggiungi la tua risposta
Jack sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 12
Tutti i Tempi: 3,064
