Salta al contenuto principale
A collection of guides and support to help with washer repair.
3478 Domande Visualizza tutte
Kenmore elite washing Machine Code error CL, control locked?
How can I unlocked??
Questa è una buona domanda?
Punteggio 2
5 Commenti
Thanks you. Holding the rinse button worked.
da
I tried everything Chime button, unplugged and plugged it back but nothing works. What should I do
da
Hi @nafishamamdani,
What is the make and model number of the washer?
da
I did the same and it didn't worked for me
da
@socorroramirez
da
Aggiungi un commento
5 Risposte
Soluzione Prescelta
Mike, this error code most likely indicates that the CONTROL LOCK has been activated. To deactivate the control lock press and hold the drain and spin button for 5 seconds. Or you can try to reset it by unplugging your machine, and plug it back in after 5-10 min.
Punteggio 10
19 Commenti:
Thanks dude...
da
For the kenmore elite the Cl error was cleared by the stay fresh button. It also says control lock above it
da
On some models, the control lock is also the chime button. Press and hold that for 5 seconds, and you're good as new.
da
On my model, Accela-wash, press and hold the extra rinse button which also has control lock on it
da
Holding the chime button for 5 seconds worked for me! Thank you! :)
da
Mostra altri 14 commenti
Punteggio 6
7 Commenti:
If you look closely under the printed word "Chime" is says in VERY SMALL letters/words "Control Lock" Wheewww - thought I was gonna have to call for expensive service :(
da
Thanks! Holding the control lock button for 5 seconds helped me! Saved me $80 for a service call!
da
It worked by holding extra rinse
da
Thanks Mike holding the chime button for 5 seconds worked!!!!
da
Worked on my Kenmore Elite!! Just press and Hold the Chime button for 5 seconds.
da
Mostra altri 2 commenti
Y'all another brand of Kenmore it's the Extra Rinse and that is also your Control Lock/ mecv
Punteggio 1
2 Commenti:
We have model number 796 and this worked for it. None of the above---unplugging it, holding chime button, etc., worked. Thank you so much!
da
The same thing for me.. but on my model I pushed the control lock for about 10 seconds and it finally reset.
da
On my model, pressing the Chime button, which is also Control Lock (CL) worked like a charm,
Punteggio 1
What if holding the control lock button does not work and unplugging it for a day does not work?
Punteggio 0
3 Commenti:
Hi @tdw80715,
What is the model number of the washer?
da
Acq76909912k-sd-87r 05464 0064
da
Same thing happening for me Acq76909912k
da
Aggiungi la tua risposta
Mike sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 98
Tutti i Tempi: 45,836
