Salta al contenuto principale
L'iBook G3 è stato lanciato nel 1999 come computer portatile per il mercato consumer.
232 Domande Visualizza tutte
What do I replace the original thermal materials with?
I am reinstalling my recently repaired logic board in my G3 900mhz iBook 14". The original thermal heat transfer materials on the heat sink were two preformed squares, the larger was a blue foam looking square, the other smaller one was gray and seemed to be a more solid version and consistency of thermal paste. Can I use the normal Arctic Silver paste for the installation or do I need to find the same type of original squares?
Thanks,
Randy
Questa è una buona domanda?
Punteggio 2
2 Commenti
Good question +
da
Thank you, I'll give that a go.
Randy
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Arctic Silver Thermal Paste will work great om the heat sink in your laptop.
Punteggio 2
2 Commenti:
Thanks. Do you have a recommendation for the thickness of the paste? The iFixit instructions say to spread a thin layer. The original materials were fairly thick, maybe up to 1/16th of an inch.
da
My experience in the matter is that it's better to have a bit too much than a bit too little. You just really need to make sure you don't have any that comes out over the edges / spills out when you reapply the heat sink. 1/16 " sounds fine to me, I just like to make sure I can't see the processor any more through the thermal compound.
da
Aggiungi la tua risposta
randy3833 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,231
