Salta al contenuto principale
Il Samsung Galaxy Note 5 (chiamato Note5) è un telefono di tipo phablet con stilo, prodotto da Samsung e rilasciato nell'agosto 2015.
Rear camera glass replacement
My rear camera glass has shattered. I was wondering if I could find a replacement piece or workaround for this issue. I'm completely comfortable with tearing down the phone, but would very much prefer not to have to do so. If an s6 lens would fit, that's fine. Any solutions?
Questa è una buona domanda?
Punteggio 4
7 Commenti
Hi, I have the same problem, what is the cost to supply & fit the rear glass?
da
It cost me under $20 for the parts, and about 15 minutes of time. Keep in mind, that's just the glass, not the sensor.
da
where do I buy the parts to fix the glass? can somebody please direct me. I just need to fix the glass on the cover, the square one
da
Here is Samsung Galaxy Note 5 Camera Glass Lens: http://www.witrigs.com/oem-camera-lens-f... , hope it can help you.
da
I bought a oppo neo 7 mobile bt rear camera glasses was broken where is available and cost of spears
da
Mostra 2 altri commenti
Aggiungi un commento
2 Risposte
Soluzione prescelta
There are no note 5 camera lenses available at the moment. I damaged my rear camera glass and the camera itself.
I replaced the camera in the device and used an s6 glass lens for the present time until parts are available. It works fine albeit the lens is noticeably too small.
Merely pry your old shattered lens off as it is held on by adhesive and stick the new one on! Hopefully this helps anyone who was in a similar predicament as I was.
The rear camera module is readily available online if you happened to have damaged it.
Punteggio 1
2 Commenti:
where do I get the new glass from and what model it is. I am new to fixing my phone and the insurance company tried to get a $165 from me for this like a need a replacement phone. This phone is not a month old for me to get an used phone from them.
da
I have the same problem. I've had this phone for 2 weeks and the INS CO wants me to pay $225.
da
Risposta più utile
those are just on there with an adhesive, heat and pick it off. be careful to not damage the bezel if you don't want to replace that as well. Don't let your tool knick the camera lens or you'll have focusing problems afterwards. be sure and use a quality adhesive to put the new one back on and you're good to go. I don't know if an s6 lens will fit or not, but if it fits-it ships. you're good to go, theres nothing special about them.
Punteggio 5
2 Commenti:
First, thanks for the excellent advice. The s6 lens works as a good stopgap, but it doesn't fit perfectly (slightly too small).
da
Bobby, quick question. What kind of adhesive is safe to use to put a new glass on? I found lens cover kits on AliExpress, but do not want to open up the phone, would rather replace glass only.
da
Aggiungi la tua risposta
Stephen Hricko sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 15
Ultimi 30 giorni: 29
Tutti i Tempi: 19,199
