Firstly, the battery is not holding a sufficient charge to boot because the LCD screen is constantly turning on. This causes a tremendous drain on the battery for a split second, if your battery is completely dis-charged like mine then you will never get ample charge into the battery for it to turn on hence why the screen keeps failing.
1. Open the back cover.
2. You will see 3x vertical ribbon cables. Carefully remove the on on the right, it is marked LCD (Convenient)
3. Plug your charger in and leave it to charge for at least 8 hours. (Use the wall socket adapter, it produced more current than a USB port on your computer) Now that the battery is not being drained constantly by the display the battery will have a chance to get some juice into it.
4. After you have left it to charge for some time unplug your charger (Crucial) , re-insert the ribbon cable for the LCD you removed making sure that it is in all the way so that the lines on the ribbon and the board are aligned.
5. Power on.
If it boots great. If not it may be time to purchase and replace the battery ($25 on eBay) and make sure that your charger has enough power to keep it charged and at 100% while in use. Beware of leaving any Li-Ion battery fully discharged for a long period
Good luck!
Votato
Annulla
Punteggio
49
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
38 Commenti
now the chagrining animation wont show up
da Jojo
Jojo, what model of the Galaxy 4 is your tablet?
da oldturkey03
Um model? all I know is that its a Samsung galaxy 4 tablet. I tried a phone charger again and it is starting to charge but the screen keeps flashing black and when I turn it on it automatically turns off. should I just let it charge for a while and then reset it when it turns on?
da Jojo
why does a phone charger work but now the one that's made for it?
da Jojo
What size is the screen? The Tab 4 comes in a 7" and a 10.1" version?
da oldturkey03
Mostra altri 33 commenti
