Salta al contenuto principale
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
clutch adjustment nissan altima
how do you adjust the clutch on 2002 nissan altima
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Donna,
The 2002 Nissan Altima has a hydraulic clutch and it can not be adjusted. The only thing you may be able to do is adjust the pedal travel. There may be a nut with a threaded rod on top of the pedal attachment point under your dashboard.
If the clutch feels funny, try bleeding it. If that is not working, try replacing the fluid. If you still have a problem you may need to replace the clutch.
Regards,
Frank
Punteggio 3
1 Commento:
Works for me +
da
I got a 2003 Altima and and the gear shift is locking up
Punteggio 0
Aggiungi la tua risposta
donnalyns1020 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 7,762
