Salta al contenuto principale
Queste cuffie bianche sono dotate di telecomando e microfono e vengono fornite con i lettori musicali e gli iPhone di Apple. Sono anche vendute separatamente. Rilasciate il 9 settembre 2008.
How do I fix a broken volume button?
On the plastic piece on the cord of the right ear bud, there is the control piece that lets you control the volume and the play/pause. The button that turns the volume up is not working, so I need to either figure out a way to fix it, or at least remove the top part of the remote.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Risposta più utile
I don't believe that you can fix the problem, likely a piece of dirt got into the volume control and is blocking the contacts however I don't believe the volume controls can be opened without destroying them all together.
It may still be possible to get them replaced by Apple, if the ipod you are using them with is still under warrantee (all new ipods come with a 1 year warrantee which will cover you'r ipod and the in-ear phones you'r using it with, however can be extended to two years by purchasing the applecare program) to check if the ipod is still under warrantee input you'r ipods serial number into this webpage https://selfsolve.apple.com/GetWarranty....
Hope this solves the problem!
Punteggio 1
Just go to android, iPhones are trash ^.^
Punteggio 0
Just get an android, iPhones are literal trash cans ^.^
Punteggio 0
i tried to open mine and then i found this site :( i broke my freaking earbuds
Punteggio 0
Aggiungi la tua risposta
John McWaters sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 14
Tutti i Tempi: 15,407
