Salta al contenuto principale
Rilasciata nel 1990 come successore della Apple Extended Keyboard. Sono stati prodotti i modelli M0312 e M3501, che utilizzano i leggendari switch tattili ALPS o gli switch lineari meccanici standard Mitsumi.
command shortcuts not working
I wiped down my keyboard with one of those lysol wet wipes and now my command key won't work ... for example: I'm in InDesign and my command C just types a c and doesn't copy. I have the extended keyboard plugged into my MacBook Pro. I wiped down both keyboards. Now I can't figure out how to restore my command shortcuts or if I got the inside of my keyboard wet. But all the keys work as a typewriter, just not the commands. I'm thinking that I somehow locked the command out or something as I rubbed over all the keys, but have no idea. Anybody?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Being able to reroute some keys may help with your trouble shooting or give you a temporary solution. For instance I have rerouted my CAPS lock key to ESC because it is more useful.
This app does the trick:
https://pqrs.org/osx/karabiner/seil.html...
Punteggio 0
Aggiungi la tua risposta
jpgrahamjazz sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 16
Tutti i Tempi: 474
