Salta al contenuto principale
L'HP Chromebook 14 è una variante della linea Google Chromebook rilasciata l'11 settembre 2013. Il numero di modello è 14-Q010DX.
Battery replacement - will this fix the problem?
This Chromebook battery will not charge (stuck at 12%). "battery_test 1" indicates battery is good. I am concerned if I spend $75 on a replacement battery on a $200 Chromebook it still may not fix the problem. Is this a known issue that is easily fixed with battery swap? If so, I might continue with the purchase. Model: 14-q063cl
Questa è una buona domanda?
Punteggio 0
1 Commento
If the laptop is out of warranty you are right to be concerned about the cost. My personal opinion is to offload the faulty laptop and buy a new one. Chromebooks are so cheap nowadays one COULD just buy a new one every time it fails when it is out of warranty.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Just an idea. If the test indicates “good” try carefully disconnecting the battery and discharging power by holding down the power button for 30 seconds and then reconnect and switch on. Any help?
How to disconnect battery:
Sostituzione batteria HP Chromebook 14-Q010DX
Punteggio 1
Aggiungi la tua risposta
Kurt Dreher sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 10
Tutti i Tempi: 433
