Salta al contenuto principale
Rilasciato a novembre 2013. 32 GB di memoria flash. 8 GB di RAM. Processore quad-core. Identificato dal numero di modello EGQ307. 19,25 x 11,68 x 1,14 cm. 1024 x 600. 4,5 ore di autonomia della batteria.
Why Is My Battery Not Charging?
My battery doesn't seem to be able to charge, or hold a charge. What can I do to fix this?
Questa è una buona domanda?
Punteggio 3
3 Commenti:
my family received 4 of these for Christmas 2014 and this had been a problem for all of them for a few months - could all of their batteries really need replacing or is there another issue that it could be?
da
It is not the Battery. The USB charging port is cheaply made. Either you need to get a better tablet, or you can replace the port. Remove the back, pull off the black fabric tape and unscrew the screws. Lift up the tech board and you will see that the port isn't even connected, so it will be very easy to replace. All you need to do is buy a new port and replace it.
da
It is the port.
da
Aggiungi un commento
2 Risposte
If you have been having trouble with battery not holding charge and now it does not charge your battery needs to be replaced.
Punteggio 0
3 Commenti:
Here are instructions on how to replace your battery: Sostituzione batteria Ematic EGQ307
da
da
Id say you have the same issue. Maybe you can claim warranty on them
da
Mine turned on for 3 weeks and nada no charge. .. Anyone else have the warranty contact information?? It'd. Be greatly appreciated
Punteggio 0
Aggiungi la tua risposta
Jonathan Scinto sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 32
Tutti i Tempi: 3,422
