Salta al contenuto principale
Il Sony Xperia Z3 è uno smartphone Android lanciato nel 2014 noto per la notevole durata e autonomia della batteria.
Xperia z3 doesnt charge
Hey, my xperia z3 doesnt charge anymore. Only the red light is flashing. It has been connected for 10 hours now and i still cant turn it on. What could i do?
I tried the reset buton then volume + and power button and still nothing.
Does anyone know, what can i do?
Questa è una buona domanda?
Punteggio 2
2 Commenti
My sony Z3 D6603 dont turn on anymore, never charge, never power on again, and I change the battery, when I plugged in with the wall charger or computer the led powered on for a few seconds and turn of, I did the comadand power + volume up and feel a vibration but never turn on any more, How can i fix my cell phone i think the problem is in the main board
da
Maybe you have the complete mainboard schema to know th number of all resistance, capacitor, condencer, IC
da
Aggiungi un commento
2 Risposte
Risposta più utile
-Try to change the charging cable or adapter, if can solve the problem, that's the reason of broken cable or adapter.
-Try the magnetic charging. If can charge the phone well, the problem may be caused by wrong USB port. If can't charge either, your battery may be broken and need a replacement.
- If new battery can't save your phone, you need take it to check the motherboard.
Punteggio 1
1 Commento:
da
has your device started working again? i am facing the same issue at the moment. please help
Punteggio 0
Aggiungi la tua risposta
infoservis112 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 8
Tutti i Tempi: 2,348
