Salta al contenuto principale
Il Sony Xperia J è un semplice smartphone che funziona con software Android.
Problem with network signal
I have a problem with my network signal.
I opened phone and found out that the connector from the second (lower) board has broke.
By the connector i mean the one that has a screw hole in it, its by the vibration mechanism.
picture of the board
So i would like to know if that's why i don't get network signal, or should i investigate more?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
3 Risposte
Do you mean this connector?
Immagine
If this connector is broken you may have a problem with network signal strength. You need to solder it or replace this subboard. A good idea is the replecement of the rf cable (a black cable connected to this subboard).
Punteggio 0
The problem that you state.have different problem with mine situation
Punteggio 0
It seems that the RF connector is damaged...kindly look at the condition maybe that is the reason and you need to replace.
Punteggio 0
Aggiungi la tua risposta
filerzr sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 19
Tutti i Tempi: 3,172
