Salta al contenuto principale
Annunciato il 16 ottobre 2014, l'iPad Air 2 è il successore più sottile dell'iPad Air.
Small IC left of home button
Hi. I have been repairing an ipad air 2 and noticed that my replacement bonded digitizer and screen assembly came with a small flap with 4 solder points on it. Upon inspection of the broken part it became apparent that a small printed circuit was soldered to the flap with an IC on it. my guess it has something to do with cover to sleep the pad, can anyone confirm this please. Thank you.
Questa è una buona domanda?
Punteggio 4
1 Commento
Does your unit work without the small ic?
da
Aggiungi un commento
3 Risposte
Risposta più utile
Yes, those components are necessary for the smart cover to work. If the part that you received doesn't have them, then you should return them for an exchange or purchase from another supplier.
Punteggio 1
2 Commenti:
Or - like I just did - remove the IC from the old screen by hotair(I used 300C for 2 sec) and resolder it to the pads on the new screen.
da
@ anders.. did it work?
da
Yes that is one of the hall effect sensor for the smart cover.
Punteggio 1
Has Anyone found a supplier for these chips?
Punteggio 0
Aggiungi la tua risposta
refurbight sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 15
Tutti i Tempi: 1,086
