Salta al contenuto principale
Questo tablet è stato rilasciato da Asus a luglio 2013. Il modello è anche chiamato ME173X. Il tablet è dotato di un display da 7 pollici, uno slot per schede microSD, uno slot MicroUSB e un jack cuffie.
Droidboot Provision OS screen
When tablet is turned on, it goes to a "Droidboot Provision OS" screen. Lists info on tablet; select; reboot ; a list of commands; last info, "Could not open /sys/devices/virtual/backlight". No buttons work except ON/OFF. What can I do? Thanks.
Questa è una buona domanda?
Punteggio 16
3 Commenti
have you tried a hard reset? hold power button aqnd volume down together fore 10seconds or so then do it again for 2-3 seconds
da Condividi
how do i solve this problem my tablet is showing this massage 'google play store has juss stopped working, whenever i try to access any application' help please
tina
da Condividi
How do I can return to fabric items?
Actually,when I do that,says that installer device ignored
I don't know what to do
Can you help me?
da Condividi
Aggiungi un commento
5 Risposte
Risposta più utile
Hi
download your firmware file from asus.com.
install fastboot on your computer.
use this command:
fastboot flash update pathOfDownloadedFirmwareFile
All of the your files in tablet will delete.
Punteggio 3
2 Commenti:
ASUS provide zip file and when we run this command it says missing text files
da Condividi
can you give more detailed information ?
da Condividi
Hi. My tab is Asus memo k011.
when I use this command:
this error appears:
C:\adb>fastboot flash update UL-K011-WW-3.1.23.172-user.zip
target reported max download size of 568967168 bytes
Invalid sparse file format at header magi
error: write_sparse_skip_chunk: don't care size 922051909 is not a multiple of t
he block size 4096
sending sparse 'update' (0 KB)...
he block size 4096
he block size 4096
OKAY [ 0.411s]
writing 'update'...
OKAY [ 0.650s]
finished. total time: 1.064s
what I do?
Punteggio 1
Mei tablet bringt das soeben was tun
Punteggio 0
the screen has stoppet can not be used
hej !
surf platan starter sen det går inte använda skärmen
mvh
Punteggio 0
forgot screen pattern of phone
Punteggio 0
Aggiungi la tua risposta
linda2222 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 29
Tutti i Tempi: 21,829
