Salta al contenuto principale
L'LG Optimus L7 P705 è dotato di uno schermo LCD da 4,3 pollici e pesa 122 g. Dispone di una fotocamera da 5 megapixel con flash LED. Ospita 4 GB di memoria interna, con uno slot SD che può contenere fino a 32 GB di memoria.
restore my phone software
i do have lg p705 and i forget my lock pattern and google account.i did hard reset but i am not able to do hard reset.what should i do to regain my mobile as earlier without doing hard reset?
Questa è una buona domanda?
Punteggio 7
Aggiungi un commento
3 Risposte
Risposta più utile
If your device is rooted, there are various apps you could run to remove the screen lock. Root it, enable adb on your device so your computer could recognize it and attempt to unlock it.
Otherwise just perform a hard reset via recovery mode on your
1. When the phone is switch off , press and hold the VOLUME DOWN key + POWER key with your left hand.
2. When the LED on the bottom of the phone lights up, touch and hold the MENU key with your right hand. You need to do this immediately, before the screen displays the LG logo. Make sure your left hand is still holding the VOLUME DOWN and POWER keys.
3. Then release the POWER key at vibration time.
4. When the LG logo is displayed on the screen, continue to hold the keys for around 2 seconds,
and then release all them at the same time, before LG logo disappears.
5. Leave your phone for at least a minute while the hard reset is carried out .You will then be able
to switch your phone back on.
CAUTION: If you perform a hard reset , all user application and user data will be deleted.This cannot be reversed. Remember to back up any important data before performing a hard reset.
Punteggio 5
how to open pattern lock lg p705
Punteggio 2
Yes it will be enternally greatful
Punteggio 0
Aggiungi la tua risposta
angikar acharya sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 14
Tutti i Tempi: 9,154
