Salta al contenuto principale
Una fotocamera da 14,1 MP in grado di scattare foto e girare video, rilasciata nel febbraio 2011. Ora fuori produzione.
How to Fix no Power
How to Fix no Power...i dont know how to fix this...
Questa è una buona domanda?
Punteggio 0
1 Commento:
It looks like I have some corrosion in one of the battery chambers of my camera, is there and way of sorting this and repairing??
da Condividi
Aggiungi un commento
3 Risposte
Check the wires and contact of the batteries. If all are good. Check polarity of batteries. If all is good. A tiny line of the circuit board is burnt because you put the batteries in a wrong way And there is no fuse.
Punteggio 0
1 Commento:
If there is burnt bit in the circuit board and no fuse what can I do to fix this problem?
da Condividi
To fix the burn in the circuit board you have to have a soldering gun, flux paste, tin- lead and good soldering skills. To repair , first you have to find the area that has the open circuit, then remove the green material that protects the cooper for corrosion. Put a bit of flux paste on the expossed part of the circuit that we previously peel. Then solder the area putting a bit of tin-lead. Find a piece of wire (small caliber..18-24 gauge)to make a bridge in the 2 areas.
Punteggio 0
I had a similar problem. The camera would power on, and I would even get a couple of pictures, the it would shut off and could not be turned back on.
Long story short. It turned out that I was using rechargable lithium batteries and the camera was expecting alkaline. I gather there is a different power profile.
I updated the settings and have not had another problem.
Punteggio 0
Aggiungi la tua risposta
cilmarbbacus sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 18
Ultimi 30 giorni: 35
Tutti i Tempi: 2,609
