Salta al contenuto principale
Rilasciato nel giugno 2009, il 1005HA si distingue per il suo design "Seashell" ed è disponibile in molte varianti diverse per quanto riguarda il sistema operativo, l'archiviazione interna e la capacità della batteria.
Problem with my EEPC
I formatted part of a key USB my hard drive C: with Gparted. so I deleted lartition hidden.
I does not happen again to install Windows XP from a USB key because it tells me that it can not find C: drive on my EEPC.
Thank you for your solutions
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
So you deleted your hidden recovery partition? Then you cannot use the recovery option in the BIOS anymore.
"C:" is not a physical drive, it is the name ("drive letter") of a file system of a partition on a drive. A proper operating system installer should first give you the option on which physical drive to install. Then you may even create a partition of your preferred size. This will get formatted and named "C" as default. Then the installation starts.
I don't know what's on your USB key, but maybe you need to prepare it newly from a proper CD image. You may also connect a disc drive via USB and install from a disc directly.
Punteggio 0
Aggiungi la tua risposta
Didier sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 24
Tutti i Tempi: 518
