Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
1233 Domande Visualizza tutte
Proximity sensor not working after screen replacement
Hello.
I have replaced my mom's screen on her iPhone 5c as a Mother's Day present, and both her and I are happy with the results. Anyways, for the past 4 days, my mom told me that when she's on a call, she accidentally presses button not the call menu (mute, dial pad, end button, etc). When she told me yesterday, I immediately knew that it was the proximity sensor, and I told her that was fixable. Earlier today, I opened up my mom's iPhone, and noticed the proximity sensor bracket on the original screen. I transferred that bracket to the new screen and put the iPhone back together. I called myself from her iPhone to test the sensor. The display turned off for like a second and it turned back on. It did that for like 3 times before the sensor wouldn't work anymore. Later on, like 3 hours later, I opened it up again and reseated the flex cable. I put the iPhone back together and it didn't work. 5 minutes later, I called myself again and the sensor was working! Then 20 minutes later, I called myself again to make sure that it was working again, but sadly it stopped working. I don't know what to do anymore to fix this. I kept looking online to fix this problem, and they didn't help. Right now the iPhone is functioning without the proximity sensor working.
Does anyone know a solution to fix this? It would be greatly appreciated!
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi Brandon,
It's very possible that you have damaged it, replacing it should solve your issue. :)
Punteggio 1
You have to insert the sensor INTO the sensor holder.
Punteggio 0
2 Commenti:
I have inserted the sensor into the sensor holder. I double checked and it was on there securely.
da
If nothing work, you have broken front camera flex...
Change it.
da
Aggiungi la tua risposta
Brandon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 305
