Salta al contenuto principale
Model number NX785QC8G, released in 2014. RK3188 Quad core ARM Cortex A9/1.6GHz Processor, 1GB DDR RAM.
95 Domande Visualizza tutte
battery wont hold charge very long
can charge tablet to full, at half battery tablet will shut itself off. Or will not come on at all unless hooked to wall adapter. has same battery that came with it when it was given to me as christmas gift. do i need new battery?
Questa è una buona domanda?
Punteggio 18
4 Commenti
I have this problem too and the tablet it's just 1 year old.
da
Hi @ Marie Laurent,
Check your sales receipt to verify that the tablet is not more than 1 year old from date of purchase and it should still be covered by the manufacturer's limited 1 year warranty.
If the warranty period is still valid follow the directions in the warranty statement to make a claim for a manufacturer's warranty repair or replacement
da
The same happened to me in my first 6 months we should look for a lawyer !! We bought trash
da
I have the nextbook nx785qc8g and mine was doing the exact same thing..This is what I did..I took the back off of it where the battery access is and unplugged it from the motherboard or whatever its called... I left it unplugged for a good 20 min and then plugged it back in....Then I held down the power button for about 15 seconds...I put the back cover back on and it powered up with no problems and I can even get into my recovery menu...(Do this at your own risk.)...Just ssyen..lol..hope this helped
da
Aggiungi un commento
17 Risposte
Soluzione Prescelta
Yes I think replacing the battery is the best choice as it sounds like your battery is at the end of its lifetime. Especially if it has been through many charge cycles. There are many factors that can effect the lifetime of a battery. Using an incorrect charger to charge the device can shorten the battery life because the battery is likely being supplied with to high of a charge current or to low of current which can eventually cause damage to the battery and possibly the charging IC on the logic board. It's not good for a battery to leave it on a charger for extended periods of time either, because overcharging can cause damage to a battery. Letting a battery discharge to often to the point it turns itself off can also shorten a battery's lifetime. Exposing to extreme temperatures often can shorten a battery's life as well. For a longer battery lifetime one should try to connect to a charger at 20% battery level and remove from charger at around 90%.
The fact that it won't hold a charge long, even though the battery charge indicator software says its at 50% may signal a failing battery. I know a 3.75v battery will fail to power on a device if its voltage falls below 3.4v, which is the point in time the device will power itself off. If the battery discharges quickly after a full charge(within an hour or two) then it should fix the issue by replacing the battery. Sometimes software may cause issues by not properly monitoring the battery's charge levels.
You could also try resetting the device to factory settings before buying a new battery. This may help if it is a software related issue. Make sure to back up any data you want saved before doing a reset.
Punteggio 10
3 Commenti:
What type of battery used? where I can buy ?
da
Also, if all else fails, before throwing the device away, try re-installing windows. I had a similar problem and this seemed to help. Windows has a glitch that tends to effect the batteries performance and can prevent re-charging of the battery as well. Doesn't make logical sense, but this true. I'm a witness!
da
Please remember one thing. All of BurnieG's answers, as well as most of the peoples answers on this are NOT CORRECT for EVERY and ALL batteries and chargers. There are so many different battery technologies out now days. I read where someone stated that all batteries would build a "memory" and therefore not charge completely if you didn't run the battery down completely before charging. They're talking about Charge Memory Effect. That USED to be some what true but not anymore. Some types of batteries won't build a memory, or rather CAN'T because of the chemical platform used to make them, like lithium-ion batteries. Matter of fact, it's better to charge lithium-ions using partial-discharge cycles. You should AVOID completely discharging them for sure. Also, after about 30 charges you should then ALMOST discharge it completely, to about 3 volts, before charging . This recalibrates the power gauge circuit. Afterward you go back to partial discharge before charging. Never store fully charged or dead.
da
how do you change the battier and where do you get one
Punteggio 2
1 Commento:
battery's pplus bulbs
da
The tablet has an internal battery you cannot just replace it you would have to go and have a certified tech fix it...may be a software issue mine did it after I factory reseted it
Punteggio 1
1 Commento:
This site provides guides to help prevent taking things to a repair shop. This device has a guide to help replace the battery if needed. One just needs to be able to locate a replacement battery and follow the guides to install it.
da
these have a problem with the battery connector not being on all the way because of a short cable you have to open the tablet up and either tape connector in place or extend cable I have fixed 2 of these tablets by doing this it would shut off at 20% or not charge fully see this link http://freaktab.com/forum/tablet-support...
Punteggio 1
The reason that the tablet shut itself at half battery it means the battery is dead,u have to buy a new one
Punteggio 0
1 Commento:
If you have a tablet how would you change the battery? Maybe just out of luck? I have the same issue...
da
the plug to charges the tablet broken
Punteggio 0
1 Commento:
The plug in won't stay connected and when it comes out the tablet will turn its self of when its not chargeing
da
I just won this nextbook at a Christmas party...and have had it for 1 week and is totally dead..this is so wrong...i nned to purchase a new battery for a new tablet.wow this is crazy...
Punteggio 0
How long should a battery keep a charge .
Punteggio 0
1 Commento:
3 hrs about depending on the usage
da
How can I fix my tablet to get back to holding a full charge
Punteggio 0
these tablets have a battery connection problem open up tablet and push battery connector all the way on use tape to keep it in place the cable is to short so when the cover is put back together it pulls connector of just enough to cause these symptoms they come from the factory like this fixed a few of them already see link bellow to enhance your tablet and where I found the info on how to fix the battery problem
Punteggio 0
haunMT's Modified ROM for Nextbook NX785QC8G
Punteggio 0
just so you know this tablet is a piece of $@$*, yes it has GREAT specs buut it just simply doesn't work.. it turns off never to turn on again.. i'm sorry ppl but its true, and its also cheap, great specs for only like 75 bucks and i'm a computer hardware designer and programmer/ administrator so i know my stuff. it just simple doesn't turn back on.
-Paul-
Punteggio 0
Why do my new nextbook8 stay charged supposed to be 8 hour battery
Punteggio 0
I charge battery all night and it only last 2-3 hours new nextbook8 why only had it 2 weeks all I do is Facebook most of the time it has a 8 hour battery it said?
Punteggio 0
1 Commento:
This means you over charged it, it's only supposed to charge the given time in the manual, maybe 2-3 hrs at most. Over charging it will fry the battery and make it hold less energy and have less power.
da
If anything replace the battery, but a good tip is to never leave the device in overcharge. Only charge the device with the given time on the manual, maybe about 2-3 hrs. Over charging the device will end up frying the system's battery and it will last only half as long.
Punteggio 0
Replace
charger
Punteggio 0
When the battery is half dead in the tablet, mobile etc,. and it is difficult or impossible to replace it would it be reasonable to buy a power bank and use that with the unit? If so this might be the perfect solution.
Jem
Punteggio 0
Aggiungi la tua risposta
algdutton2012 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 22,931
