Salta al contenuto principale
Il G4 Quicksilver era disponibile nelle versioni da 533 MHz, 667 MHz, 733 MHz, 800 MHz, 933 MHz e 1,0 GHz.
Can my cpu be fixed
a capacitor fell off the cpu. can it be resodered?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Yes it can. You might want to check the value of the capacitor to be sure it is still good. I have had one drop off due to poor soldering. I was able to resolder it using a 25 watt soldering iron with a very small tip. I had to use regular 60/40 solder that melts at 360 degrees F. It worked. Just don't over heat the solder joint.
Punteggio 0
Aggiungi la tua risposta
madruler sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 14
Tutti i Tempi: 222
