Salta al contenuto principale
Guide di riparazione e supporto per i pickup C/K venduti da General Motors con il marchio GMC, incluso il GMC Sierra.
Where is the speed sensor?
My 1992 3/4 ton truck 4 wheel drive is throwing a code, 24 speed sensor failure, where do I find this sensor?
Questa è una buona domanda?
Punteggio 2
1 Commento
I have a 1995 chevy 4by4 and the speedometer isn't work and it's not shifting into 3rd gear could it be a sensor
da
Aggiungi un commento
3 Risposte
Soluzione prescelta
8 Ball it should be located on the transfer case output shaft.
Immagine
Punteggio 3
It should be located on the driver side of the transmission near the rear where the transfer case meets but on some of them it is on the passenger side.
Punteggio 1
1 Commento:
I do not have 4 wheel drive.
da
At the rear of your transmission on the transfer case just where your drive shaft slides in
Punteggio 0
Aggiungi la tua risposta
[deleted] sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 66
Tutti i Tempi: 39,818
