Salta al contenuto principale
Il Samsung Galaxy Note II è uno smartphone noto per la sua combinazione di un ampio display e un software ottimizzato per uno stilo integrato alloggiabile nel dispositivo.
Cannot connect to wifi
my phone's wifi is not working
my wifi signal strength is very strong but it's not able to connect
the status shows obtaining IP address
and after a while it tells network disabled. Poor connection
I checked on the net they say it's because of the update of the phone original version 4.1.1 to 4.1.2 jelly bean, the update is causing the phone wifi connection go crazy
I checked for the solution, in many forums they showed to change the IP settings from DHCP to Static which I did and then after entering the wifi password there is no save option
I tried this way too..the link is below
https://www.youtube.com/watch?v=zyO66lqT...
the first way is dialing *#0011# but it's still not connecting
the second way was too confusing so I didn't try
I checked it online and I guess this problem does not only happen in note 2 but almost all the android phones
Questa è una buona domanda?
Punteggio 5
1 Commento
I have the same problem suddenly in a day. I reset my phone once and I downloaded the wifi fixer, diff., versions, it just does not work.
da
Aggiungi un commento
6 Risposte
Risposta più utile
my phone is not connecting to wifi and bluetooth
Punteggio 1
Hi Smriti
Have you thought about the wifi antenna being faulty and to try a replacement?
Punteggio 0
2nd Rssi is not available
Punteggio 0
disconnect then put your password back in. that what i did.
Punteggio 0
I can not connect wifi in my mobile
Punteggio 0
I would recommend replacing the WiFi antenna.
Punteggio 0
Aggiungi la tua risposta
Smriti Sharma sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 22
Tutti i Tempi: 25,853
