Salta al contenuto principale
Lenovo ThinkPad T500. Si tratta di un portatile business presentato nel luglio 2008. Questo notebook da 15,4″ può essere configurato con processori che vanno dall'Intel Core 2 Duo P8400 da 2,26 GHz fino al top di gamma Intel Core 2 Duo T9600 da 2,8 GHz (o Core 2 Extreme da 3,06 GHz) e con grafica integrata Intel o ATI switchable.
Why is my computer getting so warm?
After 30 minutes of use, the laptop is very warm on the bottom and is uncomfortable to have on my lap. What's going on?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
4 Risposte
Risposta più utile
There could be several reasons your laptop is getting hot. First off, laptop is a bit of a misnomer--they get hot and are meant to be used on a desk. Secondly, this laptop is a good 7 years old at this point, when was the last time (if ever) it had a thorough cleaning done on it?
Start with the basics and clean it out, new thermal paste, etc. Then if you are still experiencing abnormal heat issues (ie, burning your flesh), then there are some other issues at play here. If it is heating up after 30 minutes, though, probably needs a good cleaning.
Punteggio 3
Use your laptop on a Hard surface so the fans and case can dissipate the heat the right way. If you use it on your lap you have your body heat + the laptop heat, which will make it hotter.
http://gadgetwise.blogs.nytimes.com/2009...
Punteggio 0
Hi! You may have a problem with your fan. Try to clean your fan with a compressed air can.
If the problem persists, take a look at the Troubleshooting page to diagnose your exact problem.
Lenovo ThinkPad T500 Troubleshooting
Punteggio 0
its probably because u are not cleaning our laptop at all. or even trying to clean most of it.
Punteggio 0
1 Commento:
Does like opening the laptop and cleaning some dust with air blower and stuff help run the laptop smoother?
da
Aggiungi la tua risposta
Nickie Gurney sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 14
Tutti i Tempi: 7,200
